NS9710
I have noticed channel 58 [160.980MHz] using NXDN Digital audio in the Petersburg, VA area, and it seems to be simplex where both users talk on the same frequency.
But "They don't use NXDN on Class 1 Railroads"![]()
Not on the mainline but yards/inspection pits/engine shops/MoW sure...Ask me how I know...But "They don't use NXDN on Class 1 Railroads"![]()
And its spotty at those facilities. Spreading, but still spotty. Only CSXT PD uses it full time and fully encrypted here in Indianapolis. (though they are in the clear on the P25 TRS here.)Not on the mainline but yards/inspection pits/engine shops/MoW sure...Ask me how I know...
Regards,
-Frank C.
We get pretty good coverage in Barstow! Still not mainline ready though...And its spotty at those facilities. Spreading, but still spotty. Only CSXT PD uses it full time and fully encrypted here in Indianapolis. (though they are in the clear on the P25 TRS here.)
Because sometimes it's handy to have a conversation on a channel nobody expects... There's often a code-word or phrase. Where I worked, someone could say "Go to the highway", and it meant change channels to whatever the closest highway was.... If Rte 66 was close, both parties would change to 066-066t he doesn’t know what would be on 058, or why it would be on NXDN
If you don't think the dispatchers don't have that ability, you are really FUNNY! Over at our railroad we definitely have that ability and I know UP definitely has that ability at most dispatch setups...They'll hit up a random yard channel to talk to others if they don't want the MOP nearby to know things they're planning......Because sometimes it's handy to have a conversation on a channel nobody expects... There's often a code-word or phrase. Where I worked, someone could say "Go to the highway", and it meant change channels to whatever the closest highway was.... If Rte 66 was close, both parties would change to 066-066
Dispatchers don't have this agility in their systems and managers are still limited to the limits of ground level VHF signal properties.
I've been to the HDC. I've seen the dispatch consoles. They're not nearly as frequency agile as crews can be. The can't just select a random channel other than what has been specifically programmed into their console.If you don't think the dispatchers don't have that ability, you are really FUNNY! Over at our railroad we definitely have that ability and I know UP definitely has that ability at most dispatch setups...They'll hit up a random yard channel to talk to others if they don't want the MOP nearby to know things they're planning......
Regards,
-Frank C.
They can get pretty random considering...Yes they can't punch in a RX/TX that's different but they sure can listen to most channels.I've been to the HDC. I've seen the dispatch consoles. They're not nearly as frequency agile as crews can be. The can't just select a random channel other than what has been specifically programmed into their console.
