Csx Trenton Sub
obeone4046
Trevose Pa
Can some one tell me if csx has changed their radio's or frequency. on the Trenton sub division. I used to be able to pickup all transmissions and the hotbox detector, I now can only parts of the transmissions and have not heard the detector for sometime.
Some one said I might need a new or different antenna.
any help will be appreciated.
RadioDitch
Signals Identification Member
All over the map.
Road Channel is still 58/58 (160.9800MHz), NFM. Check your equipment, and also check that you have it programmed as NFM. Also keep in mind CSX is infamous for not maintaining detector radios.
