CT of "0"
Liverdog
Hi Rick,
I just can't seem to move completely away from .54 ... I see the following in the Wiki:
For P25 systems:
P25 call type is the call's priority - a single digit from 1 to 7. "4" is the default normal priority.
Emergency calls prefix this digit with the letter "E".
The question is, what does a "0" mean? The only thing I can see is that the TG in question has/had been patched and was the master of the supergroup.
It means the call type is unknown. It should appears as blank or a dash "-", not a zero. You likely missed the call grant and saw only the late entry messages.
Liverdog
I watched this TG (the one with the "0") over several transmissions and many channel assignments and it kept the "0". Other TGs active at the same time just showed a "4".
