I’m having problems with the sds 100 and SDs 200 The transmission Skip’s
doctordialtone, you are so RIGHT on point. Not so with the 436/536/SDS-100/SDS-200. I know someone will have something to say but I could careless! Ha HaVery true. Bob!
If you spend any time on these forums you will RARELY see any problems reported with the 996XT or 996P2 scanners.
Not so with the 436/536 family of scanners.
Would anyone be able to send me a sample file for CLMRN? I used the import function on FreeSCAN and am not hearing anything. When I upload the file to my scanner it says there is an error and the error is no apco band plan available for any of the CLMRN sites.
have you tried the free sentinel software for the scanner? that works perfectly. so does proscan. I'm not sure the file I could send would work with free scan since I dont use it. I have no problem with this system on both my sds-100 and 200 scanners
I am NOT a fan either of the SD cards, hence why I purchased the Bearcat BCD-996P2 which is a PROBLEM free base/mobile scanner with great audio and sensitivity too. People tend to OVER-BUY.thank you both for your replies, i’m not a fan of the SD card either, when i hear sirens, I cringe during the 17 seconds it takes for my SDS200 to come on.
That's a pretty vague post. No idea about your time being up but I assume you are trying to get a scanner programmed to scan CLMRN. What radio? Can you hear any other P25 trunked systems?I am still wth no State and just tried again before my time is up
I would start from scratch and program by hand instead of wasting more time.So far silence thou
