Mobile radios do produce PL/CTCSS tones (well almost all can, some older ones can't).Dave_D said:Hi all,
Is it logical to select a CTCSS tone for scanning input frequencies? Or, by doing this, am I inadvertently disabling those channels because mobile radios don't produce CTCSS tones?
Thank you!
Dave
Some but not all. Most public safety systems in the NYC area use different PLs for their inputs. If you intend to monitor input traffic, I'd suggest programming the scanner for carrier squelch.rescuecomm said:In most cases, the input CTCSS will match the output CTCSS.
Don't get offended here...Exsmokey said:Why do you want to listen to the input channel?
I like your logic.icom1020 said:Don't get offended here...
Maybe they want to check out the sensitivity of their radio or antenna attached.
Maybe they want to determine how close the unit transmitting is to them?
I don't know, does it matter? I have heard this same question a lot and it really dosen't matter why, just that most people have tried it at least once![]()
When I am out and about in my car, I scan the input of the local Sheriff's Office for that reason right there :wink:Maybe they want to determine how close the unit transmitting is to them?
No offense taken. It should not be inferred that all questions are a criticism. I thought if I knew better as to why he listens to the mobile side I could answer his question better.icom1020 said:Don't get offended here...
Nope, I think you've all pretty much covered it. I thank you!!!Exsmokey said:Dave, we have answered your basic question of the mobile frequency having CTCSS on them. Is there anything else you would like to ask about why and how CTCSS is used on mobile frequencies?
