I'm trying to configure an F6011 for one channel, with a 218.1Hz decode, with microphone hanger Off or On ground.
Using CS-F3020/F5010/F5020 software Ver. 3.4.
I have the C.Tone, RX set to 218.1Hz.
I have Googled this over and over with very similar results(I realize often erroneous), but little other specific search results return.
Google suggests:
1. [Done] Open the Channel Spreadsheet: Go to Memory CH -> Zone where your frequencies are configured.
Verify the Sub-audible Tone: Enter CTCSS frequency (e.g., 100.0 Hz) into the C-Tone RX column.
2. [Can't find or non-existent?] Change the Log-In/Squelch Mode: Look for the Squelch Mode or Log-In column (often located further down the row or right next to the tone selection). Change this setting from Carrier to CTCSS/DCS. This forces the radio to remain muted until it detects the explicit code.
3. [Not found] Link the Operating Signaling: Look for the RX Code CH or Signaling option on that channel line. Ensure it is mapped to Tone or LMR/PMR tone squelch so the microprocessor blocks un-toned traffic. The Model is set to LMR.
Step 2 would probably solve this, but not found.
Under Common, Key & Display, Hanger Action, I have the Off Hook Monitor set to OFF.
So I have carrier squelch regardless of mic hanger state.
Do I need to be using PMR mode to accomplish this?(thought was for European band plan, etc.)
Any advice greatly appreciated
Google suggests:
