Paul-Nuneaton
- Joined
- Oct 3, 2020
- Messages
- 5
- Reaction score
- 0
When I first tried CubicSDR on my Macbook Pro, I had a 4K external monitor connected and it all worked and looked normal.
I am thinking of taking it out for portable use at the weekend so unplugged my external monitor to see if it was readable on the 13" build in screen.
When I did it looked like the attached image.
I can't hover over the waterfall to select anything normally. If I want to select the centre of the waterfall, I need to point where the centre would normally be, not where it actually is.
If I want to change mode, I have to point above and to the right of the mode I want until I see it highlighted, I can't click directly
I've closeed the machine down and restarted with only the internal display, but it made no difference.
I deleted the CubicSDR APP and removed the preferences files and plist files from the Libraries folder and reinstalled, but it is the same.
It is a pity I didn't have it on the internal screen only when I originally installed it then I would know if it was always like this.
I am running on Big Sur, so that might be an issue, but if it was, then I would expect the problem to be on either display.
Anyone else had this issue with CubicSDR?
