Curious about strange transmission
2036angie
Hello! I've discovered a strange sounding transmission and was wondering if anyone knew what this was. It can be found between 147 - 148 MHz. It is constant buzzing with rhythmic
beeping approximately every two seconds. I have attached a recording of it and would appreciate if anyone can tell me more about this transmission. Thanks!
  • Strange signal .zip
ecps92
Taxachusetts
seems your ZIP folder is corrupted, unable to open.
What Specific Freq did you find this on ? Likely DMR or P25 users as 147-148 is generally Amateur Repeaters
dlwtrunked
It is not a zip in the link in his post but a .aac audio file. show a signal a periodic burst. Does not sound like any amateur mode and if in the U.S. most likely some local interference.
KevinC
The big K
Super Moderator
I'm everywhere Focker!
I would suspect it's something as simple as noise generated by a router, modem, cable TV box or something like that. Start unplugging things and see if it goes away.
2036angie
Thanks! I tried this, but it's still happening. I'm also a few blocks away from an active AM radio station. I don't know, I'm at a loss
2036angie
I found a recording of static that sounds the same as what's coming through the radio, minus the beeping. It's a PAL broadcast. I'm attaching a video of that sound.
  • PAL.zip
