Custom information
HoDo
Baltimore, Maryland
I can't seem to find where I can go into the UASD and put in my name and info on the startup screen in case it gets lost or worse stolen.
I program using BCTool, but I think you change the info in Uniden UASD, any help would be great. I have a Uniden 396T.
KE5BCP
Analog Man
Lewisville, Texas
It will be in the "Miscellaneous" tab of the configuration file under "LCD Display".
HoDo
Baltimore, Maryland
Thank you it worked. I had to select all my sytstems and then change it under Misc and then upload to unit. I then went into BCTool and reloaded my systems and tgid's in case something chenged by accident. When done the opening screen info was still there.
bwilborn
Evans, CO
In bcTool go to "Radio > Radio Settings". You can change the startup screen by changing the data in the "Opening Message" section.
-- B
