BC125AT: Custom Scan
ashundoi
Genoa, Nevada
I just bought a BC125AT and have read most of the user’s manual. I understand how to scan the various Banks. How to turn them off and on. I need help setting up a Custom Scan. I haven’t been able to figure that one out yet. I want to be able to scan 163 – 174 MHz only. Can someone either point me in the right direction for a tutorial on this or perhaps help me with a step-by-step process.
Scan125
UK
The easy way is to use Scan125 :)
However the manual way is to:
1) Press Search [Srch] button
2) Press Hold [Hold] button is scanner starts searching
3) Press Function [Func] button
4) Press Program [Pgm] button
You should now see a menu:
Save Frequency (highlighted)
Program Limits
5) Use Scroll button to select/highlight "Program Limits"
6) Press Enter [E] button
7) Use Scroll button to select/highlight "Search Bank n" where n is the number of the bank you want
8) Press Enter [E] button
You are now on the edit screen for your chosen Search Bank - will default to "Lower" and show the current frequency
9) Press Enter [E] button
10) Enter 163.0 on keypad
11) Press Enter [E] button
You are now on Lower with the new 163 frequency
12) Use Scroll button to select/highlight "Upper"
13) Repeat steps 9, 10 (enter 174.0) & 11
14) Press ./Clear [Clr] button repeatedly (goes back through menus) to get back to "Search Mode"
ashundoi
Genoa, Nevada
Thank you very much for your prompt and detailed reply. I'll give it a try and let you know how it goes. You're obviously very well versed in the operation of this scanner and I appreciate you taking the time to help me. I don;t recall seeing anything about this in the manual that came with my new scanner.
Dudley
ashundoi
Genoa, Nevada
I followed your instructions. Again thanks for the details. I ran into one issue. Most likely my misunderstanding. I missed something and modified Bank 10 rather than creating a new Bank 11. Bank 10 DOES run the scan between 163 & 174. Would you mind expanding on your step #13 so I know how to create a "new" Bank.
Scan125
UK
You can't create a Bank 11. There are only 10 Search Banks just as there are only 10 Scan Banks.
ashundoi
Genoa, Nevada
Clicked on your avatar and got this; " You do not have permission to view this page or perform this action. "
wtp
Port Charlotte FL
ashundoi, you are not free to do everyting here yet.
you need some more posts for the mods to give you permission.
wtp
Port Charlotte FL
he is new, so, hover over his avatar or name, another box will pop up. then click on the about box.
