Customizing RMU2080D
Not all radios require licensing. FRS/MURS radios do not. Also, a larger company like Hampton may have nationwide licenses that local employees may not be knowledgeable about.
As for licensing, it's not hard. Difficulty level of getting a license shouldn't be used as a reason to not get licensed.
hurricaneoleg
I get it and, like I said, I will make a reasonable amount of effort to get licensed, I want to and prefer to be licensed, being on the right side of the law has always been my preference, like any other normal human being... I'm just trying to understand whether this licensing is mostly a formality that isn't enforced or is something that can potentially cost me money in the future, I'm sure you understand that I'm not just brushing this off and moving on.
KevinC
Other
Home
It’s most definitely enforced. But it’s like a lot of other things in life, it’s not a problem until you get caught.
hurricaneoleg
True, you're 100% right... I really don't want to get it to a point when I have to suffer the consequences of a very preventable problem causes by my own laziness or shortsightedness, I'm prone to procrastinating some things I'm not sure about, even though I'm very meticulous and hard-working by nature, or so I think of myself.
ecps92
Taxachusetts
Since it seems you are in the hobby, toward the end of the manual it lists all the possible frequencies this radio can handle.
Program them in, listen, see what is NOT used nearby and apply for those on your license. :)
hurricaneoleg
Will do. I can't just apply for all uhf frequencies in 400-500 spectrum? Because I work at two different places, my main goal is to have my 7550e work on 4 different frequencies in three different settings, I want to have one radio I have to carry, not four. But that's a different subject entirely...
KevinC
Other
Home
You don’t apply for the license, the business does.
If the radios are running in their "out of the box" state, it's probably on 464.500 or 464.550. Those are two VERY common UHF business itinerant frequencies. It's no wonder you are getting interference.
There are a lot of other UHF itinerant channels to choose from. Using something other than what the radio has programmed right out of the box will probably fix the interference issues. Set a PL/DPL tone other than the first one, and you'll probably be good.
As for licensing, if you have not done it before, it's probably going to be very frustrating. It is possible to do it on your own, but those new to the industry rarely are successful on their first try. Since these radios belong to the school, let them pay for getting it done legally/correctly. There are plenty of companies that will assist you for a small fee. They'll find a suitable frequency and file all the paper work for you. I'd strongly recommend having the school administration pay to have that done. It really is quite painless and much, much, much cheaper than an FCC fine.
Contact these guys to get started:
hurricaneoleg
Thank you, I thought this was a formality, like a fishing license, if it's not then I will definitely have the school do it. I already spent the money getting the data cable for Motorola cps, no way I'm spending any more money on something they need to do on their own.
However... I still need to get a license to use the hytera I bought... Which means, for me personally, I may have to force my boss to pay for that company you spoke of.
KevinC
Other
Home
Not sure about your state, but in my state a fishing license isn’t “a formality”, it’s the law. And you can and will be fined if caught fishing without one.
hurricaneoleg
What I meant is that getting a fishing license in my state of NY or PA is a quick and painless affair, with no exams or egregious amounts of money required. Getting this FCC License seems to not be this at all.
It's not. The frequency coordinator will charge per frequency, but it's not expensive. I think I paid $125 each, or something darn close to that. That was a month or two ago using the same company I linked to.
The FCC charges, but again, it's not much, and way cheaper than a fine.
As for yourself,
As an individual, you will not qualify for a business license. If it's a legit business need, then follow the same steps as the school. Frequency coordination may be required if you want your own channel. If the itinerant channels will do, that makes it even easier.
hurricaneoleg
As for yourself,
Makes sense thank you for giving me this information.
Again, being new to this I didn't expect PROGRAMMING A STUPID RADIO to require a bunch of licenses, rules and a ton of software I've yet to obtain.
I've been doing it for about 30 years. That's exactly what it requires. Often a lot more, depending on which radio service it is. I do some marine stuff, and have to have a special license myself just to program the radios.
There's a reason why people make careers out of this.
My employer has a lot of systems and a lot of money invested in telecommunications. Screwing up and getting tagged by the FCC isn't worth it to them. Keeping guys like me on staff to stay within the boundaries of the rules, as well as keep everything running, is necessary.
And lucky for me, it pays really well.
Here are some examples of folks getting fined for not having a license or having freqs programmed channels that are able to be used even if no one ever used that channel / freq. This is from the part 90 FCC rules,
90.427 Precautions against unauthorized operation.
(b) Except for frequencies used in accordance with §90.417, no person shall program into a transmitter frequencies for
which the licensee using the transmitter is not authorized.
  • costco no license.pdf
  • bearcom 2.pdf
  • bearcom oscars.pdf
  • cal state no license.pdf
