I just purchased a Super Scan Duck from Antenna Warehouse. It's the exact same length and style as an RH77CA... just rebranded. It's a good antenna -- much better at all bands over the stock, with the exception of 800MHz, which is _slightly_ worse than the stock, but virtually unnoticeable unless I am on the fringe. It's okay, however, because the 800MHz TRS I listen to is strong enough for me.
I have a few systems I listen to that are still conventional. When they switch to an 800MHz TRS (which they inevitably will), I'll probably want a bit better 800MHz performance than what I have.
So, I've read that the Seeker 800MHz antenna is probably the best for 800MHz scanning, if only a bit better than the RS800MHz. It's length is 11.75". The RS800MHz length is about 7".
So, let's just say I were to cut the 15.75" Scan Duck down to 11.75". Theoretically, could the cut antenna's performance then be at least almost the same as the Seeker?
I'd also like to make an interesting note: most people here have stated that the Seeker has better 800MHz performance than the RS800MHz. This is interesting, because if the Seeker was a 1/4 length, the resonant frequency would be 238.98MHz. If it were 1/2 length, the resonant frequency would be 477.96MHz.
Calculating the RS800MHz resonant frequency, if it were a 1/2 length, it would be resonant at 802MHz! How could the Seeker be better at 800MHz?
