Hello all,
i have a strange problem using d-star. I have 2 transceivers. The first one is an ID-5100, the antenna is directly connected to the radio and everything is ok, i can consistently hit 4 UHF repeaters and 1 VHF repeater in DV mode.
The second radio is an IC-9700 and it appears to have a problem working on d-star. I disconnected the antenna from the ID-5100 and i connected the antenna on the UHF connector on the back of the IC-9700. As far as i can tell both radios are configured identically. I can't hit any UHF repeaters in DV mode. i have the same problem if i connect the antenna on the VHF connector. Also the radio is totally def in DV mode. The radio works fine on VHF/UHF FM so i can safely rule out the antenna as the problem.
Another thing, on the ID-5100 the squelch is working in DV mode. On the IC-9700 the squelch is not working, no matter what i do with the squelch knob position i can't hear a single sound in DV mode.
Any ideas ?
thanks
73
Sylvain
Any ideas ?
thanks
73
Sylvain
