KeithJoseph
Still working on my amateur radio callsign.
I should be able to hear the channels marked with a D on Abilene edacs provoice right? I've got the 325p2..
If you have Paid upgrade, and no encryption is used, yeahI should be able to hear the channels marked with a D on Abilene edacs provoice right? I've got the 325p2..
Ok so why can't I hear them then?
Does your signal meter move, do you see talk groups, did you use RR for frequencies, have you tried a LCN discover to make sure you have all frequencies for system?I've got the provoice upgrade.
YesSo you are confirming that you paid for Provoice upgrade? I see some encryption on the system as well?Abilene (EDACS) Trunking System, Abilene, Texas
Abilene (EDACS) Trunking System Profilewww.radioreference.com
Would you mind submitting that info to the database so we can fix that?The database is wrong. Everything but PD-1 is encrypted as far as PD talkgroups are concerned.
Edited to add that HMC is encrypted as well.
