D104 Mic & Converting It
K2GOG
Mid Hudson Valley
not sure how this made it into this particular forum, but the answer is yes.
when it came to that particular mic, I always wired it up to an 8pin and made adapters to use it on other radios.
if you know the pin set up on the radio, you may have a diagram under the d104 mic base. unscrew the 4? screws and check if it is there.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
It appears pin 5 on the Realistic is used to ground a relay in the power supply for shifting from receive to xmit. Thus, connecting pin 5 xmit to contact A on the Make-Break Section in this JPG may be a solution.
The Cobra does not use a relay for shifting.
IdleMonitor
The Ottawa Valley - Eastern Ontario
ok, what is that, and could I see a picture of this?
As well, sorry for putting it into this forum, but didn't know which other forum could've suited the question. Besides it is for a CB so....
policeMonitor said:
yes you can but to make it easyer you could use one of the 4pin to 5 pin push in
