D104 with a Johnson Messanger 250
kf4eyr
plant city florida
you say d104 but what stand are you using? d104 is the head the stand it is mounted on is what matches the head to the radio,,,, the tug 8 stands works excellent with the old messengers as does the ug stands do the only difference is one is an amplified stand where the other is non amplified,,, these 2 works best with a radio using relays for switching from transmit to receive,,,,,
tomwkinder
Toledo, OH
D104 with Johnson Messenger 250
Attached schematic on bases. I have the T-UG8. If this will work, I need to know how to wire the D104 plug connector to the Johnson radio. Haven't done this stuff since the 70's and everyone I know that could help has passed on.
