Anytone D578UVIII read/write error.
Plasmastorm73
Jacksonville
Hello, I am having some issues trying to program this radio. I have the newest CPS and FW, plug the radio in and put it into programming mode, the com port shows up, I am able to update the FW, but I can NOT read or write to the radio through the CPS.
I am running Windows 10 with the most up to date patches and updates.
I have installed and uninstalled the driver several times, turned off signed driver security, factory reset the radio, tried every USB port on my computer, every available com port, Tried every USB cable I have including very high quality cables, NOTHING!
Any suggestions?
chief21
Summer - Western NC; Winter - Tampa Bay FL
(Read the next post before trying anything!)
With the 878, AnyTone suggests installing the CPS only (without the driver) as the native Windows drivers will often work fine. With your 578, suggest you uninstall the AnyTone drivers and reboot the PC. Maybe you'll get lucky and it might work OK without the AnyTone driver.
chief21
Wait.... What?
I just re-read your post and it sounds like you might be putting the radio into "programming mode" when attempting to write to/from the rig with the CPS. If I recall correctly, the special "programming mode" is only necessary when updating the rig's firmware. You should be able to read/write the CPS by just connecting the cable to the radio and selecting the correct port in the CPS - no special mode is necessary.
Plasmastorm73
Jacksonville
Wait.... What?
Thanks. That will teach me to follow along with a video on how to program the radio.
Problem solved!
nullifi3d
Another thing I noticed - for some reason, this radio really hates to be programmed with a BT-01 plugged in via cable mode. Not sure if this carries over to the stock microphone, but worth a note for anyone else having issues.
