Anytone D868 deleting non-assigned channels
N9JIG
Sheriff
Moderator
Far NW Valley
I have an Anytone D868UV and will likely be getting a 578UVPro soon. Using the provided Anytone software to program it is pretty easy.
What I would like to be able to do however is to delete a bunch of channels from the "Channels" library based on if they are NOT assigned to a Zone.
I had downloaded a regional codeplug that has several thousand channels, about 3/4ths I do not need. I deleted a bunch of Zones and edited or created others as well as added or edited many channels in the library. That leaves a couple thousand channels scattered thruout the library that are not assigned to any Zone. Is there any way I can easily delete them en masse or would I just have to go thru them one by one?
In the alternative is there a utility that would indicate if a Channel is assigned to a Zone?
