Dairyland Power new radio system
n9upc
Land of mixed mode digital comms
Does anyone know what type of DMR system Dairyland Power is running and if it is encrypted? Do not want to plop down money on a DMR scanner for nothing.
Was hoping that I could use one of my UHF DMR radios in poor man's trunking to monitor but so far no luck.
peewee007
Gary Hanson
Somerset , Wisconsin
This might be helpful if ya haven't seen it:
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Was a hodgepodge of analog and conventional P25. Now, it is a Moto Capacity Max system. Doubt if they are running any encryption. Supposed to be expanded to additional regional electric co-ops over time (more radios and towers). Mostly mobile radios in use with some portables. TT
n9upc
Thanks and this begs the question on how to monitor a Moto Capacity Max system. Do DMR scanners do it? Can a Tier 2 DMR radio monitor it without affiliation?
TampaTyron
Phoenix, AZ
Cannot monitor with a motorola radio unless it is setup on system with the radio serial number loaded into database. You would need a scanner or some other radio with passive DMR monitor capability. TT
ScanWI
MN & WI DB Admin
Wisconsin
The system is no encypted and is a DMR Tier III system from Motorola, they have branded their system Capacity Max but it is still a Tier III system.
Yes the DMR scanners will monitor it, and non-Motorola DMR radios should be able to monitor it passively. I have had no issue with Hytera and TYT listening to it.
n9upc
Perfect and I will try listening to it tomorrow.
n9upc
Well might need to dig out the SDR as passive (promiscuous) monitoring real quick today did not work. Now granted it was an Anytone and I saw traffic (Rx light coming on) and in analog heard the DMR brapp but no decode of any data or audio heard.
