N
N_Jay
Guest
P25 Trunking IS 9600 BPS.
You would have a very hard time buying a new 3600 BPS (Smartnet) system today.
laggroup said:There is a caveat in the grant iteslf; the radio must be not less than 16 channels, it must be VHF, and it must be APCO P25 compliant. There is a reason.
MMIC said:The minimum needs to be more than 16 channels. From my experience, if they are planning on setting up any sort of interoperability talk group sets, they will eat those 16 channels up very quickly. Everywhere I have seen struggles with a minimum of 48.
laggroup said:No argument from me. I was reading the grant requirements, which stated that they would provide funding for programming radios provided that they were not less than 16 channels. We bit the bullet and picked up 10 of those Kenwood P25 VHF portables instead of dealing with reprogramming, which wouldn't have worked anyways.
MattRiley said:Does anyone know which existing radios will be supported by this / a statewide system? EMS here just got two grants for 20 new radios, they are the F70D's from Icom, and obviously P25 compliant. My Question is, just because the state is requiring new grant-purchased radios to be P25 compliant, is there a chance they still will not trunk although they are P25?
nslt204 said:The state wide system is going to be a "backbone" system that ties existing systems together.
If your radios are meeting the fed guide under the grants I would not be concerned.
The local systems will continue to exist. A the statewide backbone won't have users just on it. The users will need to be on a "local" system.
Think of it as a statewide patch.
N_Jay said:If you want then to work on a trunked system, they have to be trunked radios.
If the sate is providing conventional "interoperability" access to the system, then you could access that with a conventional P25 radio.
General rule of thumb:
Find out what you need, before you buy. (Applies to most things in life):wink: :wink:
