biglaz
Howdy,
If you've ever monitored the Dane county VHF paging channel you've probably noticed that every page gets broadcast twice, repeating itself. Does anyone know why they do this?
Secondly, occasionally I'll notice situations where two pages are happening on top of each other because they were done too close in succession. This seems to usually happen when the first page is fairly long (thus it takes a while for it to repeat) such as for a structure fire, and then the dispatcher realizes they forgot to page someone so they immediately send a second page while the first is still repeating. Usually what I've noticed happen in that situation is the repeat of page 1 will stop (or be muted), page 2 will begin, and then the rest of page 1's repeat will finish after page 2. Then, page 2 will repeat, including the part of page 1 that happened during/after page 2. Though I've also seen it happen where the first page is successfully interrupted. What causes this? Is the dispatcher doing something they shouldn't, or is it just some sort of quirk in the software that repeats the page transmissions?
