Is Daphne still using the NXDN system does anyone know? Or have they moved over to the P25 system? I'm sure they're still encrypted wherever they are.
I've used DSD with an SDR to monitor Foley back before they went encrypted and I noticed that tags were really hit and miss across all the agencies. Don't think I heard Daphne off the Foley tower, just Foley and occasionally Robertsdale or Fairhope.
I've not heard Fairhope PD since the days they were on VHF, not even sure what system they use today. I sometimes get a lot from Bay Minette on Nexedge but other times not so much. Whilst my main radio is an SDS200, I use SDR to try and figure out some details of systems. All I need to do with P25 systems using DSDPlus is get on a CC but I can't get that to work with Nexedge. May be my setup in the batch files? I usually use an SDRPlay but also have a few of the cheap USB dongles that do not perform as well.
DSDPlus >>logfile.txt -T -E -e -UA30 -UI30 -wsl633.710 -wel436.1015 -wcl744.247 -fn -fN -i1M
Fairhope started out with the NXDN system, but then switched to the P25 which is where I believe they still are, but they're encrypted. The past couple of days I have tried to figure out DSD Plus and it seems like too much of a headache to use.
If I can find my notes, I'll post what I found as far as units and who used what. Much of it isn't still accurate because of the encryption although I did find some unencrypted NXDN traffic patched over from the Sheriff's P25.
Baldwin County is very nice, if there were better airports in the area we'd definitely consider relocating.
I think the county's various fire departments are also simulcast in the clear on the NXDN radios, too.
Jack Edwards in Gulf Shores is now "Jack Edwards International Airport" and has its own dedicated tower. They're building a new terminal and looking for some (limited) commercial service at some point, so you may get your wish for a better airport. Or at least one that's more convenient to the beaches! It was said that prior to this update, it was the busiest airport in the nation without its own tower.
