Dare county Fire/EMS scanner online
jsncrso
KN4ZVZ
Outer Banks, NC
Hey guys, I set up a feed for Dare County. It's a feed for their analog 155.3735MHz paging channel. In this feed you will hear paging for all Dare Country fire departments, EMS, and rescue calls. In addition, you will be able to hear traffic originating on Dare Central's side, but you will not hear any traffic from units (and won't until I or anyone else sets up a digital scanner feed).
Anyway, PLEASE let me know of any errors or tweaks, and I will address them as I can. I'm currently trying to lower the hum but it's proving to be more difficult than I anticipated. Thanks!
KE4ZNR
Radio Geek
Thanks for taking the effort to setup the feed :)
I will give it a listen later on this evening in some down time and let ya know if anything sounds wonky.
Thanks again for setting it up!
73
Marshall KE4ZNR
jsncrso
KN4ZVZ
Outer Banks, NC
No problem. I'm about to go online with NOAA Weather Radio Cape Hatteras (KIG77) so there may be a bit of downtime later this evening, but after that it should be running permanently.
KLO5078
Dare Question
jsncrso--this sounds like a question for you .I know Dare is using their own P-25 system--Dare also has a bunch of talkgroups listed on the VIPER system. Are any of these being used or any of the legacy frequencies listed in the database?
jsncrso
KN4ZVZ
Outer Banks, NC
They have VIPER talkgroups, but they aren't used as far as I know, unless there's a large emergency (such as a hurricane) or for some odd reason a unit is out of the county. Also, the legacy frequencies listed in the database are no longer used. I do know there is a backup analog channel,(I've been told its the old 155.925MHz fire frequency, but I haven't confirmed this, though I do know they have one since we do mutual aid with Currituck Country, and Hatteras island also has a couple of VHF tac channels).
One of the other guys who are more familiar with the new system will have to chime in on this though.
Webodisk
Silent key.
Virginia Beach,VA
154.25000 158.95500 186.2 PL Hatteras Island Rescue Squad
155.26500 107.2 PL Hatteras Island Rescue Squad
and have you ever heard anything on 154.325 for avon ?
robschonk
Avon, NC
I haven't, but I haven't listened to VHF since the Dare 800 system came up. I'll program them in now and let you know if I hear anything.
Rob N4JKL
KX4KDH
Powells Point, NC
Please GET RID of the VHF in the scanner feed. It is particularly annoying since it kills other traffic going on while the scanner is jumping from the 800 system to VHF.
I was listening to an archive of a particular incident that occurred here, and missed half of what was going on because of this. Nobody cares about the tones.
jsncrso
KN4ZVZ
Outer Banks, NC
The intereference bothers me more than it does you, trust me.
Much of the "jumping" is just interference and not because the scannner keeps going back to VHF, although it does contribute to it. The delay in picking up transmissions sometimes is because I'm also scanning NC VIPER and it takes around 2 full seconds for each digital system to be processed by the scanner whereas a county radio will decode a transmission instantly (this is very evident when a radio is cleared then re-keyed abruptly). My scanner also cannot prioritize talkgroups (such as fire dispatch, not sure if it's the scanner or a radio system limitation) on the 800 system so if I delete VHF, you will still miss just as much if not more traffic due to interference or law enforcement talking.
Unfortunately, most of the problem is just the processing limitations of my 996xt scanner. I'm planning on replacing my scanner with a BCD536HP or one of the new Whistler ones in the near future and I may get rid of the VHF dispatch then if the performance is satisfactory.
stowaway
I personally like hearing the tones, which up until last week when I had to borrow the power adapter I kept my old analog scanner still going at home. When I have the stream up at work I don't pay 100% attention to the talking, but if I hear a tone I listen to what's going on. The level difference is perhaps the annoying part.
KX4KDH
Powells Point, NC
I don't understand scanning VIPER around here... Nothing goes on but the occasional A-100 unit calling Raleigh, or vice-versa.... The feed would be a lot more seamless without VIPER, or VHF.
kc4jgc
Virginia Beach, VA
Rob N4JKL
Check /w K4HAT Richard (or is it Donnie W4HAT?). He's a member of Buxton FD. He should be able to tell you what's in use in the island.
KX4KDH
Powells Point, NC
Richard (K4HAT) is chief of Frisco VFD. Randy is W4HAT.
Everything in use on the South end is listed in the Database. Both Fire repeaters, Hatteras Island Rescue repeater, and assorted TAC freqs.
jsncrso
KN4ZVZ
Outer Banks, NC
KX4KDH, you are right. Originally I had VIPER up to listen to HP and Dare MedFlight, but HP doesn't say a whole lot and MedFlight is now (AFAIK) fully patched over to Dare's 800 system. You can also every once in a while hear patient reports to OBH, but scanning that sort of thing is prohibited against this site's TOS and many agencies have been using cell phones for that anyway.
I'll go ahead and lockout VIPER completely and see what that does. Let me know if it improves things. I'm still going to turn it on during hurricanes and other disasters for state agencies but I think scanning it full time is pointless for the most part.
KX4KDH
Powells Point, NC
You'll find that Dare Medflight uses the talk group labeled "DMF LZ" within the Dare 800 system. No need to monitor VIPER for that. Can't remember the TGID right off hand. EDIT.... TGID 14618
KX4KDH
Powells Point, NC
And you're probably right about it being patched thru VIPER, which is why it sounds like absolute crap when DMF is calling in.
