Darkice showing its streaming but it isnt actually
williamGB
Chester, UK
Hello,
I have darkice running on my raspberry pi 3b+, I have 2 usb soundcards and 2 different config files. I run both config files at boot with a .sh script. Yesterday we had our DSL router replaced with fibre and switched to a different provider. I connected the rapsberry pi to the new network, but darkice has not been running correctly since the switchover. When i run darkice with the script, it shows
DarkIce 1.3 live audio streamer, http://code.google.com/p/darkice/ DarkIce 1.3 live audio streamer, http://code.google.com/p/darkice/ Copyright (c) 2000-2007, Tyrell Hungary, http://tyrell.hu/ Copyright (c) 2008-2013, Akos Maroy and Rafael Diniz This is free software, and you are welcome to redistribute it under the terms of The GNU General Public License version 3 or any later version. Using config file: /etc/darkice.cfg Copyright (c) 2000-2007, Tyrell Hungary, http://tyrell.hu/ Copyright (c) 2008-2013, Akos Maroy and Rafael Diniz This is free software, and you are welcome to redistribute it under the terms of The GNU General Public License version 3 or any later version. Using config file: /etc/darkice2.cfg Using ALSA DSP input device: plughw:1,0 Using POSIX real-time scheduling, priority 4 Using ALSA DSP input device: plughw:2,0 Using POSIX real-time scheduling, priority 4
However, Broadcastify shows both feeds offline. I am also streaming it to my own icecast sever, and it doesnt show up there too. I have another rpi running darkice for a different feed. I had the same problem, but that one seems to be working correctly after a software update and re-installing darkice. I have removed darkice and did a software update on the pi, but it still doesnt work. Any ideas?
williamGB
Chester, UK
Update:
I ended up changing the feed port from 80 to 8500, and it worked! Hope this helps anyone else who has the same problem.
saddlebrookfd
West Milford, NJ
How did you get in to change the port? I'm thinking I have the same issue. Dark ice is running on the Pi. Two-tone detect is sending files to IamResponding but broadcasting is showing the stream is down
williamGB
Chester, UK
On the darkice.cfg file,
Change
port = 80
To either 8500, 8080, or 8000.
Apologies for the late reply, i only just saw this.
