Data Channel on LTR - Columbus, OH?
msharp
Columbus, OH
In reference to B&C Comm #1 http://www.radioreference.com/modules.php?name=TRSDB&sid=1618
This LTR has the following freqs:
451.9375
452.2375
452.2875 (Data)
452.3625
452.4375
These are the same freqs listed in the fcc lookup site too.
I've never seen a LTR with a data channel and I can't get my BC 780 XLT to scan it correctly. I'm sure its the order of the channels are not being on the correct channel.
The above link doesn't have a certain order, but 1,2,3,4.
I tried programming these like most traditional 5 channel LTR systems,
Channel 1,5,9,13,17 with no luck. There's not a lot of activity but I have caught some conversations when manually tuning to each freq, but not using the LTR trunk search/scan mode.
First I'm wondering if that data channel shouldn't be in there or if anyone else has a setup that works.
Thanks.
jimsokol
SW Michigan
There is one type of LTR (don't remember the type) that uses a control channel. Current scanners won't track that type.
...jim
EricCottrell
Boston, Ma
Hello,
When you say data do you mean a frequency that has a continuous carrier with occasional voice on it or do you mean it keys up with data transmissions?
It is possible to transmit data over LTR. The data has a home repeater and group like the other voice groups.
LTR-NET and Multi-Net LTR systems have a frequency that is always on. LTR-NET systems should be trackable using a scanner supporting LTR. Multi-Net LTR systems are not trackable using a scanner.
73 Eric
msharp
Columbus, OH
It's a never ending continuous data signal.... Could be a newer LTR system that uses control channel, but again, i can get talkgroup ID's when holding on any the frequencies (other than data channel). But to do a full traditional trunk search/scan it never stops.
FPO703
Planet Earth
That sounds like some other sort of data. Not LTR Data. Almost like Telemetry of some sort
16b
Central Ohio
What you are hearing is "bleed-over" (adjacent channel interference) from a cab company's mobile data system operated on 452.300 (found on FCC records). The transmitter appears to have a very strong signal, so that's probably why you are hearing it on 452.2875.
COTA used to (maybe still does?) use the same type of data system, and I always hated that sound because their transmitter was so strong it would often interfere with my reception of UHF police, ham, and business frequencies.
msharp
Columbus, OH
Never thought about that, makes sense :oops:
I started excluding that frequency but never have gotten the correct order.
Maybe I or someone else may crack the correct order soon. Been too hot lately to attempt anything that might frustrate me :wink:
FPO703
Planet Earth
If you happen to have a PRO 92 or PRO-2067 you might be able to figure part of it out.
