Data interference on OPC Common 142.770
phyberoptics
Orangeville, Ontario
Anyone else noticed the data interference on 142.770? It sounds like a control channel from an adjacent frequency. I've heard it in Mississauga, and Orangeville (not sure if that's from the same transmitter site or where that even is). Heard it on several radios too, so I don't think I'm halucitooting. :)
mciupa
Canadian DB Admin
Moderator
I'm here a lot
It's been a problem since I wrote this:
08-14-2016, 12:46 PM
If you give 142.770 a listen, you will notice a persistent "noise" being transmitted for seconds at a time, then it breaks and shortly resumes again.
Kind of annoying when you are trying to scan.
exkalibur
York, Ontario
It's coming from the TPS tower at Yonge and the 401. That's what you get for having a CSQ repeater in Toronto...
motomeso
Ontario
It sounds like local intermod coming from the site. If they had the repeat disabled like they're suppose to it wouldn't be an issue.
On a side note, you can hear that damn tower just about everywhere.
gary123
I have heard it in Kitchener and Goderich and London occasionally. Maybe someone will make a call to Metro Telecom :).
can anyone identify the source of the data on the repeater input? ie 138.755 or whatever?
Jammin_Jay
i believe The comm centers can activate the repeater, by switching it off or on, and also in sequence with others depending on the radio traffic from that area that warrants it from which ever agency opp and local police that are in that tower location. I dont believe they are picking up this noise in the comm center or they would have acted upon this asap. You can check the input, but not sure thats it, could be leakage from intermod. Who knows. The amount of Intermod in Toronto terrible it would require 15 x filtering to supress 10 percent of it, lol. I think the input frequency is standard 4.020 split negative, which would make it 138.750
gary123
Thats the issue is it intermod? or is it an adjacent freq. The fact the repeater is repeating it is fixable but obviously someone does not want to or cannot disable the repeat function at that site. Identifying the actual signal that is being picked up by the input will go a long way to eliminating this headache.
DaveH
Ottawa, Ont.
If the problem is at the site e.g. intermod, we could listen to the input 138.750 from a distance and might not hear it.
Repeater offset is -4.02MHz in this case, but there are lots of exceptions in Fleetnet.
I recall several years ago, military aircraft on the US side operating in the 138MHz range were interfering with a Canadian ground repeater; forgot the frequencies and other details, would need to dig back into my notes. Probably not the cause of the OPC repeater problems here but worth keeping in mind.
Dave
Also, knowing any other transmitters at that site could provide a clue.
motomeso
Ontario
If a tree falls in the forest and nobody heard it, did it really fall?
