I never seen data skip work well. More often, it will not skip under the conditions you would like it to. If you have a carrier with any kind of modulation, ie; "data", it will usually not skip it, thinking instead, it is a signal intended to be monitored. A condition where it will skip almost 100% of the time is when you have a dead quiet carrier. This however may be the worse time to skip. Often, during an emergency, when dispatch, or an officer keys up the mic, they may pause due to something they just saw, or heard, then continue on with the important message...of which you may miss because data skip has already moved on!
