shajoe44
Can a data slicer be used with Unitrunker and if so how do I set it up. I am using Windows XP.
This thread was for the Retro version of the program. In the new program I could support such a thing.Oh, wow.. 2005. Sorry.
I agree. It isn't supported but could be easily added.High speed bit sampling off a discriminator comparator seems like a win.
Look at the Dumper source code found in the original Trunker source (vintage 2001).is there any reading material on how to go from the raw (zero-crossing) timing (above) to the 'M36' messages in the GRE CCDump stream?
They flag bad data with a trailing "E" or "Err". The Unidens are not any more dirty. They just don't tell you which frames failed the checksum.IIt's not clear how the GRE protocol communicates the bit-errors or confidence. I know this is a problem with Unidens, which seem to have a pretty dirty data stream.
Consider it done for the next release.GroundLoop said:Cool! If you are willing to add UniTrunker support, I will write the Arduino code, post it here
I'm way outside my ken here, but is there any reading material on how to go from the raw (zero-crossing) timing (above) to the 'M36' messages in the GRE CCDump stream?
I know UniTrunker does this internally, but I'm curious to know if this could be externalized to make the data more compact.
p119 of the PSR-500 User Manual describes the format
http://www.greamerica.com/download/manuals/PSR-500v1.3_Manual.pdf
That's a very good point. The simpler and more raw the data, the more protocols can use the same format or adapter.Also keep in mind that Unitrunker is but one application that will consume this data, and that trunking (of whatever format) is not necessarily the only use.
