Database has system type entered wrong
AmbitiousHornet
Holland
Using the Sentinel software and database on a SDS200. From USA->Michigan->Ottawa->Ottawa->Schools - Zeeland Public Schools in the database, the first four frequencies listed are not NFM, they are some form of trunked system. I can find no way to change this (using my best guess) using the software and I am unaware of how to petition for a change to the database. Please advise.
AmbitiousHornet
Holland
Welcome to the RR forums. The RRDB relies on user submissions to stay up to date. If you have verified the correct info feel free to submit a database update. Be sure to review the submission guidelines beforehand since you've never submitted an update before
I was originally addressing the Uniden database, which is wrong, and I also checked the RRDB, and it is also wrong. The problem is determining what type of trunked system it is and I don't have access to that type of information. Until I can edit the Uniden information, I cannot determine the radio system's nature.
KevinC
Other
Super Moderator
Home
Someone will have to figure out what type of “system” it is and submit that to the RR database. That’s why I moved this post to the Michigan forum for local visibility hopefully.
Whiskey3JMC
DXpeditioner
40.0417240450727, -75.23614582932653
If you're referring to the license linked here, emissions are MOTOTRBO/DMR. You'll need the DMR upgrade for your SDS200 to figure the system out. $60.00 direct from my.uniden.com. Uniden Sentinel feeds from the RRDB so once the latter is updated, so will Sentinel after you choose Update > Update Master DB. Usually updates are released to Sentinel the following Monday
