Dauphin County - Motorola p25 System
ocguard
PA/MD
I'm working on getting the tower map to those who PM'd me for it.
I'm curious about something I've just noticed regarding the non-simulcast portion of the P25 system. The 450/460 sites all share a common frequency of 460.125. These sites are not simulcast. I'm curious as to what the function/purpose of this common frequency is among non-simulcast towers. Any ideas? The sites are too close together for this frequency to be " re-used" for different RF at each site.
markandjere
Franklin County, PA
Wirelessly posted (blackberry: BlackBerry9550/5.0.0.1015 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
Would someone please tell me how to program Dauphin into my pro 96 the right way? I still can't get it to work....Pms are welcome.
I don't know what my problem is but the whole thing is really frustrating to me. Thanks
hosehead88
Central PA
I am also still having the same issues. This scanner has never worked with this system.
csvff78
Pittsburgh
Here is some data I recorded a while ago.
FileVersion:4
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : 1E8
System Name :
WACN : BEE00
Tower Number (Decimal): 101
Tower Number (Hex) : T0101
Tower Description : (null)
Control Capabilities : Data,Voice,Registration
Call Sign(s) : Unknown
Timestamp : Sat Mar 28 14:25:53 2009
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth
00,851.00625,0.00625,-45.00000,"Confirmed",0.00625
01,762.00625,0.00625,30.00000,"Confirmed",0.00625
02,468.82500,0.01250,3.00000,"Confirmed",0.01250
03,500.00000,0.00500,7.50000,"Confirmed",0.01250
04,450.00000,0.00625,10.00000,"Confirmed",0.01250
-Frequencies
#Format: Channel,Usage,Frequency,Input Frequency
"02-2529","c",500.43750,503.43750
"02-2615","a",501.51250,504.51250
"02-2679","a",502.31250,505.31250
"02-2681","a",502.33750,505.33750
"02-2687","v",502.41250,505.41250
"02-2699","v",502.56250,505.56250
"02-2701","v",502.58750,505.58750
"02-2709","v",502.68750,505.68750
"02-2716","v",502.77500,505.77500
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
102,"T0102",1e8,"04-0516",453.22500,""
103,"T0103",1e8,"02-2525",500.38750,""
104,"T0104",1e8,"02-2591",501.21250,""
107,"T0107",1e8,"04-0542",453.38750,""
108,"T0108",1e8,"02-2551",500.71250,""
109,"T0109",1e8,"02-2666",502.15000,""
110,"T010A",1e8,"00-0000",851.00625,""
bmlure
New Franklin, PA
FileVersion:4
-TowerInfo
System ID : 1E8
System Name :
WACN : BEE00
-Tables
-Frequencies
-Neighbors
Has anyone used the info to make a table for the Pro-96?
dste
Renton, WA
-Tables
-Frequencies
Hint
Look at the freq and notice that all are 02-something
The offsets are:
0 for 00-xxxx
4096 for 01-xxxx
8192 for 02-xxxx
and keep adding 4096 until
61440 is 15-xxxx
The fact that all freqs are 02- means you only need Table 02 for the base and step.
So Base is 468.825
Step is 12.5
Offset is 8192
Easy!
markandjere
Franklin County, PA
Well ................I entered the above info into my Pro-96 and lo and behold I am now recieving Dauphin County! Many ,many ,thanks.......................
pghscanner
For the Pro-96/2096 what do you set Ch Hi and Ch Lo at?
I have loggings from other tower sites, and table 4 is also used.
dste
Renton, WA
Lo - hi -- offset - base - step
8192 12287 8192 468.825 12.5
16384 20479 16387 450.0 6.25
vinzep491
i am now working on the 197, i am in wrightsville york co. using antenna on the roof, i am set to custom table is this correct, thanks
You don't need a custom table for the 197 and Dauphin County. Just program in the TRS control freq's and select P25 AUTO system type.
jimsmowin
WRIGHTSVILLE, PA
i am still having all kinds of trouble getting my 2096 to work on dauphin system, works great on york, something is not right, thanks for help my 197 works fine
hosehead88
Central PA
Can any of you who have this working create a P96 file or any other upload file? I still can't get it working.
