Dauphin County - Motorola p25 System
vinzep491
Can any of you who have this working create a P96 file or any other upload file? I still can't get it working.
May I recomend buying a PSR or RS model while they are so cheap. Programming is ten times easier.
As far as making a file, I do not have the capabilities as I use all GRE products. Good luck,.
hosehead88
Central PA
Thanks for offering nothing but a sales pitch. My question was about a RS issue. If you have no contribution, don't type.
Sent from my GNex with Tapatalk.
vinzep491
There is no need to be rude. And noones trying to sellvyou anything. You think i see a cent from anything you may or may not buy? No.
This is a positive community about helping others. Someone may find my response helpful. Buying a new model WOULD make your programming easier on tthis system.
No need to be an arrogant pos. Good luck with your problem s.
hosehead88
Central PA
What help did you offer? None.
What was rude was you responding with worthless drivel and wasting my time. Your need to be validated by posting a completely irrelevant response hoping for a virtual pat on the back is laughable. Don't like my tone? Then learn when not to type. If you have no guidance on my particular problem then STFU. It is a more important piece of netiquette than your perception of my arrogance.
markandjere
Franklin County, PA
Hose,
This is what I have entered in my PRO-96. Base-468.825 Offset-8192 Step 12.5 Control channels programmed in and set to "TABLE" in CC Mode. I may be in your general area Friday and could maybe meet somewhere if you want. I will tell you that I am by no means an expert but would be willing to look at your scanner and set up those settings . I know what its like with the frustration I had the NJSP systen set up in my 96 and was working on re-doing the V-folder and now it's not working................Let me know. A PM is welcome.................Good luck.
hosehead88
Central PA
Ran it through the P96 software and miraculously I am receiving the whole system. Set it up for a bank for County Fire, one for HFD, one for HPD and an EMS bank. Forgot to remove encrypted TG so I am doing a lot of pressing of L/O. Will address on next upload. If anyone needs the file, let me know. It also includes a bank of conventional for Cumberland, Adams, Perry.
Thanks, Brother. This is great.
Hose, <br />
markandjere
Franklin County, PA
Glad you got it working! I have had my share of frustration. Love that feeling when it comes together and there it is. Enjoy...........Now on to that NJSP problem........
hosehead88
Central PA
Forgot to close my banks. Had every TG coming across. Now things are quiet.
Thanks again.
vinzep491
The only gaps in the DB are fire tac TG's for various townships. I IDed some recently (Swatera Ops for one). The problem is that they are used sparingly, only when the agency is on scene for the most part.
All the unENC pd tg's are ID'd, as well as the minicipal tg's and the unENC ems.
markandjere
Franklin County, PA
I have the following TGID's in may 96 but no tags:11803 - 11804 - 11808 - 11810 - 11815 - 11817 - 11822 as well as 21817 - 31071 - 31073 - 31075 - 31801 - 31802 - 31805 - 31808 - and 51031 - 51056. Some are ENC. some are not. These are where I thought the gaps would be in the DB.
vinzep491
ALL of the 118's are police department talkgroups used either by individual departments of special operations groups. They are 100% enc all the time. The only way we will tag those is to get our hands on a PD radio and do some testing... so those are going to stay blank..
All of the 310's are EMS enc talkgroups, 100% enc all the time. They are most likey EMS to hospital talkgroups to call in when en route, and are not going to be IDable.
I believe, and do not quote me, that 21817 is the ENC fire command tg, but I will have to check my notes to verify.
As for 51031 and 51056, I am not sure which township they blong to, but they are municipal talkgroups. I will do some research on those.
daneg
Lancaster County pa
If I enter in the freq's for the TMI site, would I pick that up on the Lancaster/dauphin line around RT 283. When I go up to dauphin we visit people in middletown so the TMI site would be great as they are a stones throw away from it.
vinzep491
Yes tmi would give you some good traffic from that end but also program the simulcast freqs since that carries all the systems talkgrops and you will be able ti recieve both tmi and simulcast at your location
Twister_2
Dauphin County, PA
I've been (attempting) to monitor the system since its birth with my PRO-106. It never was able to decode the simulcast system at my house good enough to be enjoyable to listen to. I thought about upgrading the firmware but the scanner barely works anymore. If you lay it on its side, it'll shut off.
So I'm in the market for a new scanner. I heard Uniden's firmware updates for the 996xt help out. Who listens to the simulcast system and and can provide insight on which scanner works the best?
Thanks!
markandjere
Franklin County, PA
I would like to send out a HUGE THANK YOU to whoever submitted the newest update to the Dauphin Co. system . THANKS ! That is what I've been waiting for ............
vinzep491
Whats the ENC status of the newly ID"s TGID's for PD township-specific channels.
I was under the impression they were all strapped but the DB shows Digital unenc.
