Davidson County Fire
BigLebowski
Piedmont NC
Can anyone make sense of the mess that is in the database for Davidson County Fire, such as what is actually programmed into the radios and in what zones?
Thanks!
yardbird
Concord, NC
I talked to the radio vendor today at the Fire College he advised me that Davidson County Fire is now on a repeater just like Ems done.
I asked if he could advise me of the input frequency and he didn't want to say.
I done some checking on my own from the database and came up with the input frequency for the Davidson Fire Repeater.
Fire Repeater
Tx: 158.940 Mhz
Rx: 154.160 Mhz
PL: 88.5 Hz
Ems Repeater
Tx: 158.970 Mhz
Rx: 155.235 Mhz
PL: 88.5 Hz
As far as I know the rest of the channels are non repeatered fire ground channels and the other fire repeater on 154.400 Mhz is licensed to the Davidson Co Firemans Association.
I really don't monitor the fireground channels just dispatch. If I need to listen to an incident while in the area I will either grab to scanner or the JT-1000 and program the fireground channel in.
If I can find out more the weekend I will be glad to pass it along.
David
BigLebowski
Piedmont NC
David,
Thanks for the info!
It looksl ike the database has been cleaned up somewhat since I did any detailed programming. I am frequently in Davidson County, so I like to keep all of the fireground channels programmed in.
What I am mostly trying to figure out is the order of the Fireground channels and what PL is in use. I see that Fireground 02 is listed twice, once as a base station with an 88.5 PL and once as a mobile station with no PL. I also see that the rest of the fireground channels are not listed with a PL. Is this correct, or have they just not been verified? Is there any PL on the traffic channels?
I assume that the Central Fire, Pilot Fire, and Gumtree Fire frequencies are private tactical channels used by those departments?
yardbird
Concord, NC
Jake,
The duplicate channel for Davidson Fire Ch 2 is the talkaround channel. Same as Ch.1 but it does not access the repeater.
The rest of the fireground channels are probably going to be on 88.5 Hz Pl just like the rest of the channels are.
154.205 Mhz is acually not a private channel for Gumtree. It is and actual dispatch channel for them for Forsyth County. Even though there station is in Davidson County they have a district in Forsyth as well.
Same hold true for Mt. Mitchell Fire in Cabarrus County. They also have a district in Rowan County they are dispatched by Rowan County as well.
There are several departments up your way that are dispatched like this. Another would be County Line and Sheffield-Calahan departments in Davie County. They are both dispatched by both Davie and Iredell County.
Julian Fire in Randolph Co., is dispatched by Randolph on VHF and Guilford Co. on Low Band. Same thing goes for Climax Fire in Guilford Co.
Talked to a Julian firefighter today, and he was wearing two pagers. One on VHF and One on Low Band
Mecklenburg was this way till about a year ago. County Fire was on VHF and First Responders was on UHF Med 9, even though the First Responders were in the same department. They finally took up the Med 9 pagers and redone the tones. Now all County dispatching is done across VHF it seems to be working really well. I know the firefighters were tired of trying to keep up and were three pagers. The carry Alpha Pagers as well.
The 153.830 Mhz is a Private channel for Pilot Fire Department. We used it several years ago when I took Firefighter I & II Alarms & Communications. It is also used by Davie County as a fireground channel.
154.130 Mhz is a private channel for Central Fire. I think at one time the channel was also used by Lexington Fire for dispatch as well.
It's crazy, but if it works then that is the only thing that matters.
Hope this helps
David
KM4WLV
Rockwell (Rowan County), NC
Jake,
I can't find my list of the Davidson stuff but David is right. Davidson Fire uses the PL of 88.5 for all of the FG channels. I know this isn't much, but I hope it helps. Still looking for my hardcopy book with everything in it. As soon as I find it I'll let ya know.
Thanks !!!
NC4AB
Wallburg, NC
Davidson County VHF
The following are the updated frequencies for Davidson County NC:
DESCRIPTION TX RX TONE W/N
FIRE DISPATCH 158.9400 154.1600 88.5 W
TAC 2 154.3250 154.3250 88.5 W
TAC 3 153.9500 153.9500 88.5 W
TAC 4 154.4000 154.4000 88.5 W
TAC 5 151.1000 151.1000 88.5 W
TAC 6 153.9050 153.9050 88.5 W
TAC 7 153.9650 153.9650 88.5 W
TAC 8 154.1000 154.1000 88.5 W
TAC 9 155.7900 155.7900 88.5 W
TAC 10 155.9550 155.9550 88.5 W
TAC 11 158.7600 158.7600 88.5 W
TAC 12 159.0900 159.0900 88.5 W
TAC 13 151.0475 151.0475 88.5 N
TAC 14 151.0625 151.0625 88.5 N
TAC 15 155.4225 155.4225 88.5 N
TAC 16 155.6775 155.6775 88.5 N
TAC 17 156.1425 156.1425 88.5 N
TAC 18 155.6850 155.6850 88.5 N
EMS DISPATCH 158.9700 155.2350 88.5 W
Lexington Fire F1 155.8200 153.8000 88.5 W
Lexington Fire Tac 2 158.8800 155.9850 88.5 W
Lexington Fire Tac 3 154.1300 154.1300 88.5 W
Lexington Fire Tac 4 154.0700 154.0700 88.5 W
South Repeater 159.1950 154.4000 88.5 W
North Repeater 159.1950 154.9800 107.2 W
I have submitted the info to RR for an update to the database.
RMPDCOP
Nashville, NC
Taken care of.
