Davie County 800 OPS channels
SD70MAC
NC
Does anyone know what the Davie County 800 OPS channels are? I would imagine that these are simplex channels.
drayd48
I have not heard of any simplex channels for 800 in Davie county. I'm in Cool Springs and we don't have nay simplex for Davie in our radios for mutual aid. They are probably the channels on VIPER that are not simplex.
You might be talking about the simplex 700mhz used statewide, all counties have access to these channels. In Wake county they call them "DIRECT" channels.
700 Simplex F1 = 769.006250 12.5 KHz spacing
700 Simplex F2 = 769.018750 12.5 KHz spacing
700 Simplex F3 = 769.031250 12.5 KHz spacing
700 Simplex F4 = 769.043750 12.5 KHz spacing
700 Duplex F5 = 770.962500 Rx/800.96250 Tx 12.5 KHz spacing (DVRS OPERATION ONLY)
DVRS ANALOG (DVRSA) Operation uses 156.7 Hz PL Note the Frequencies are for the
PORTABLE/MOBILES…NOT FOR THE ACTUAL DVRS UNIT…INVERT FREQS FOR DVRS
DVRS DIGITAL (DVRSD) Operation uses NAC $400 Note the Frequencies are for the
SD70MAC
NC
I'll give them a try thanks.
SD70MAC
NC
They are not Viper TG. Ask your Davie M/A department its in their radios . Your Dept should be able to have access . OPS 1-4 ,there may have been more. Don't ask for this forum ,but for your department.
When I had access to the radios I never really give it a second thought. I had to leave that because of my job, because I don't have time to devote anymore .
If Davie County programmed them correctly (not all counties have the NAC correct) the NACs should be;
County SO NAC CODE LE NAC CODE FIRE NAC CODE EMS NAC CODE PS NAC CODE
Davie $530 $630 $730 $830 $930
