DB9 to USB
ki6bu
Mesa AZ
The serial cable that comes with the 396T to connect to the PC has a DB9 connector on the PC end, will a DB9 to USB adaptor work as long as the USB driver is installed in the PC, instead of buying the USB cable from Uniden?
Thanks for your help!
bravo14
Polk County FL
I bought a serail port to a usb adaptor it works for me paid 30 for it. The usb connector came with software. make sure your com is set 4 for usb than again there is a auto detect section on it also.
DaveIN
Founders Curmudgen
West Michigan
Yes you can use any com to USB adapter you want, but the idea of the USB-1 cable is that it is the only cable technically supported by Uniden and does not require the adapter.
MacombMonitor
The USB cable from Uniden is a Serial-to-USB adapter.
