DC freqs
Gasman315
Wis
I am visiting Dc and took the Uniden 396 with me in the car today. I pick up Montgomery county clearly . The scanner is deaf in DC with an occasional data .I have the frqs of 868.6875 868.8625 868.8875 868.9375 entered. I do an Id search and recieve nothing. If any body has any suggestions please pass them on. This Uniden is new to me but I have no problem with the Apcc0 systems @ home or other counties out here.
Thanks Nate
freqhopping
Misread you. Lots of buildings in the way is my guess. I've never tried to listen to Mont. Co while in DC.
Gasman315
Wis
DC Freqs
Thanks for the input. I might not have been very clear.The feqs I posted are the one from the Radio Reference Data base for DC Public Safety in the 800 range that I have entered in the scanner. Are these wrong?
freqhopping
Those are the Montgomery Co freqs you posted. So if what you are trying is DC, then what I originally posted is what you should do.
Gasman315
Wis
Your freqs disappeared can you repost plsease, and thanks for your help!
Gasman315
Wis
Freqs
freqhopping
For DC Fire/EMS the control channels are 852.61250, 852.63750, 852.66250, 852.68750
Set the trunking for a Motorola Type 2/APCO 800Mhz and set the 'control channel only' option to Plan 1.
The main talkgroups to program would be:
1616 Zero 1 Dispatch
1632 Zero 2 Main
1648 Zero 3 Fireground 3
1680 Zero 5 Fireground 5
1696 Zero 6 Fireground 1A
1712 Zero 7 Fireground 7
1744 Zero 9 Fireground 9
1760 Zero 10 Fireground 2A
1776 A3 Fireground A3
1808 A5 Fireground A5
1824 A6 Fireground 3A
1840 A7 Fireground A7
1872 A9 Fireground A9
1888 A10 Fireground 4A
1904 Zero 11 EMS 1
1920 Zero 12 EMS 2
1936 Zero 13 EMS 3
For DCPD which must be put in another bank, the control channels are 460.02500, 460.10000, 460.15000, 460.20000
It is a Motorola Type 2/APCO UHF system
Base: 458.7750
Spacing: 12.5
Offset: 380
Most activity will be on these talkgroups:
16400 1st District Operations
16784 1st District Tactical
16432 2nd District Operations
16816 2nd District Tactical
16464 3rd District Operations
16848 3rd District Tactical
16496 4th District Operations
16880 4th District Tactical
16528 5th District Operations
16912 5th District Tactical
16560 6th District Operations
16944 6th District Tactical
16592 7th District Operations
16976 7th District Tactical
16624 Citywide 1
17360 SE-1 (Sp Evts)
17392 SE-1A
17424 SE-1B
17456 SE-2 (Sp Evts)
17488 SE-2A
17520 SE-2B
17552 SE-3 (Sp Evts)
17584 SE-3A
17616 SE-3B
17648 SE-4 (Sp Evts)
17680 SE-4A
17712 SE-4B
There are many more you could program.
Gasman315
Wis
dc freqs
Thank you . If you evey get to Michigan and neeed help with the multi towers let me know!
Nate
