dcpete
tenley
Wash DC
I have been enjoying my pro96 with no problems until now. I dont know why but when Iscan mpd/fire
I can not get dispatched calls. The scanner only picks up tact channels where it was picking up dispatching
channels? The scanner stops on say 3d but all I hear is unit to unit district to unit. No dispated calls?
I hope someone understands what Im saying. Also if I scroll through the bank for mpd I can hear dispatched calls but cannot hold onto anyone district. Thank you for your help.
mikext
Dc Trs
Using the Pro-96 to scan trunked systems, to stop on a particular trunked station ie: MPD dispatch press and hold the trunked button while the conversation is active and you should see "id hold" on your screen. Manually scroll through to DCFD Disp in your scanner then press func then trunk this manually puts a particular trunked channel in the id hold. To trouble shoot make sure your trunked banks are closed by using func-5 , make sure that DCFD isn't locked out, and make sure that the talk id is correct.
