devicelab
Whacker Extraordinaire
With my SDS-100 this system was working just fine -- but then the last few days, I'm noticing a LSM-type issue. It seems that when the scanner detects voice activity on a TGID, the TGID starts flickering on the display -- on/off -- for multiple times. No audio comes through. This is NOT an encryption issue.
I'm using an external antenna and there should be zero signal issues. The really funny thing is that I have my 996P2 on the same system and it's decoding perfectly.
I tweaked the scanner settings. On P25, I usually use NAC enforcement so I tried disabling that. I don't use filters so I tried various filters. No change.
Another odd point is that it doesn't reproduce 100% of the time. It's probably 60/40 right now. The more I listen the more *some* TGIDs are able to be heard. Still it's very flakey. And like I said, this just started happening.
I tried swapping antennas and also a rubber duck. No change. I tried erasing the scanner and reloading my FLs. No change.
So last step was to take a debug log and post it here.
If someone can analyze this then I'd appreciate it. I know at the very end of the log, the issue was showing up. This log has a mixture of working and not-working so it should be fairly obvious -- I hope.
SYSTEM: Port Of Seattle (P25) Trunking System, Seattle, Washington - Scanner Frequencies
SDS-100 LOG: https://www.dropbox.com/s/x6nhkom9jaskukb/log0020256.zip?raw=1
If you need Pro96com details then I can submit that as well.
Cheers!
Cheers!
