Decent battery for XTS3000
Clarky
N/W Florida
Can someone please recommend a decent battery for the XTS-3000, without breaking the bank? In addition, is there a good vendor to use? Thank you in advance.
cmdrwill
So Cali
Depends on which charger you have. I like the Li batteries.
Imax_expert 4200mAh Lithium NTN9862D Battery for MOTOROLA XTS5000.
WB9YBM
I'm not sure how widespread the chain is, but around here there's a chain called "Batteries Plus" that I've had good luck with...
Maybe not 'break the bank', but might put a dent in it. Power products makes good stuff.
A great company I've bought batteries from everything from MT1000 to jedis, XTS is Hitech USA on ebay 35 bucks for 4000mah li-ion - "Hitech USA(Japan 4A TOP) For Motorola XTS" Their pictures are crap and not always correct, I knows its counterintuitive but the quaility of the product is excellent and has a 1 yr warranty If your stuck I'd give them a shot. the manufacturing is better than any chinese battery Ive bought. They use japanese cells and assembled in taiwan which may not mean much but I havent had problems
and honestly, anything more expensive than that I'd buy the real deal Impres and Ive bought used Impres batteries before but the seller showed it was good on an Impres battery data reader. I have one myself and if the seller has a return policy you can find out yourself on unsure batteries, if you have the data reader
mbnv992
Also known as MT2000 man on Batlabs since 2001+
AZ
IMAX makes some fantastic aftermarket batteries that fit most Motorola portables almost as good as OEM.
Power Products is another good one.
EBL is the brand I use for all my Jedi batteries.
WB9YBM
They are an Ebay seller
Hadn't realized that; we've gone there in person, and one service I like is that they'll tell you to bring the equipment along to make sure the replacement fits. Not sure if they do it all the time; at least for my lap-top & scanner they did...
