Chickenhawk56
- Joined
- Nov 19, 2016
- Messages
- 32
It was the NA-701C. I tested it in the band it is designed for. (453, 462 and 464 MHz)There's your problem. The 701 is tuned for ham band, not commercial uhf. They make a separate 701C model for commercial and gmrs frequencies.
Interesting idea!I have noticed the same issue with almost all my HT antennas: SWR is way crazy for the band I would like to use it for.
I had bought a Surecom SA-250 Antenna Analyzer and proceeded to "fix" these antennas. Almost all of them were too long and could easily cut them down to reach my target frequency. First I took the plastic tip off the end of the antenna, then cut a small piece off. I was sure to put the little tip back on before testing because it does make or break the tuning.
It was worth a try ... considering I now have three almost useless antennas. I checked SWR on the lowest frequency I was licenced for (453) and the highest frequency I was licenced for (467) and the SWR was lower on the lower frequency. This indicates an antenna a bit too long. Considering the resonant frequency of the NA-701C should be 455 MHz, I felt is was worth a try. I snipped 1/4" off the end and replaced the end cap, exactly as my friend has suggested above. I tried it at exactly 455. SWR actually went down. Woohoo!
Sadly, it only went down from 9.01 to 8.6. Rats.
Just for fun I decided to snip another 1/4" inch. Ooops. Too much. The SWR now climbed past 11.
Oh well. I was destined for the garbage can sooner or later anyway.
I am still convinced that Nagoya has been faking the old "fake" thing, and uses that as an excuse if anyone actually bench-tests their antennas and finds these crazy high SWR numbers.
What I cannot understand is how other reviewers report much lower (1.4 or so) numbers on the NA-701 (ham version of the 701C) and the NA-771 antennas.
