BM82557
Drift Correct is set to whatever the PPM correction for your dongles is. Have you calibrated your dongles to determine what their PPM correction is? They are all different.
@Dog thank you. my "window" is much better now. my RSSI is 50, but hopefully that is due to indoor antenna placement temporarily. i had to change drift correct. the "drift correction" box is currently unchecked. should i change it back to "checked" since my "window" is near 0?
le from computer
i will delete my "voice" receiver. i will take a screenshot of the settings for personal use upon reinstall. i will physically remove "signal" dongle" from computer to prevent any mistakes when i reinstall the "voice" dongle.
thanks @Dog both receivers are showing "ready/running."...finally. i am not seeing the box that normally pops up in unitrunker which shows the green status bar and all the current calls being scrolled through. i will check the driver as you mentioned.
@Unitrunker thanks. I will check tonight and respond. I can calibrate again using my local NOAA station since that is a solid signal.
