@Dog both my receivers have good rssi and window during calls. my site window status bar is solid green most of the time. sometimes during calls the audio sounds a bit like a robot. where should i start first? the first thing i think of would be the antenna.
for example during calls my VOICE receiver is: rssi 70 and window 9
my signal receiver is rssi 64 and window 4
It is probably DSD+. Watch the scope on DSD+ and Unitrunker voice VCO. They should be about the same height. You can lower the volume on your virtual cable to adjust the signal DSD+ receives. If the volume is to high it can interfere with the decode. Do you see errors in the command window? At the end of each line it will have e:somerandomstuffhere.
Sometimes I will resize the scope windows so they are the same size and play with the volume of virtual cable until the are the same height.
Something else I have had to do is lower the sample rate slightly to get good decode. The sample rate on my voice receiver is 2.112 msps.
Your signal and correction looks awesome. I wouldn't mess with that.
