Decoding Motorola Telementry
Joseph11
On my local trunked system, there is some type of Motorola Telementry that controls a Sprinkler System. Is there any way to decode this data? I attached a sample of the data. Thanks.
  • Telemetry.zip
Looks to be bursts of square wave at roughly 300 baud. With a little patience and a program like Cakewalk, someone could look for a sync pattern at the start of each burst. After that, who knows what structure was used in the bits that follow.
WayneH
Forums Veteran
Super Moderator
Your master site
The problem with decoding data such as this is that it is specific per data system. What it tells you won't be something you can figure out unless you know someone that works on the system.
I believe it's MOSCAD btw. http://www.moscad-systems.com/
-Wayne
KB8UYC
Ypsilanti Michigan
I am not trying to sound rude or anything, but Why would you want to decode it? What would the point be? There would be nothing to do even if you could decode it??
Eric
pfish
Eric
He's probably just bored or something :p
Its like, people like to listen to race cars, utility companies, cell phones, and even a regular (music) radio. I personally don't like to listen to those. Other people do and I don't understand why.. I probably never will either, but its their choice, not mine. :)
Joseph11
Yes, I'm very bored. Thanks for all the replies.
N_Jay: What are those values that you posted?
N
N_Jay
Guest
Miscellaneous BS. The idea is that all you would see is port locations and commands. All of which would just be numbers (probably natively in Hex).
So;
port 12345 turn on
Port 12345 turn off
Etc, you wont know whether a particular port is the tower light or the command to dump raw sewage into the nearby stream. :)
Joseph11
Thanks. I thought it would be eaiser, but I guess not. I have another question for now. Is there any way to decode the low-speed subaudible data on analog Motorola Voice Channels?
Al42
Long Island, NY, USA
There has to be, since that's how the Pro-92 tracks a Motorola trunked system.
WayneH
Forums Veteran
Super Moderator
Your master site
Yes, do you have a PRO96 or 2096? It already does it when you hold on a trunked voice conversation.
There isn't much to the data. All it says is which talkgroups are active on the system, and it also trims them slightly (Search for posts by me on Priority Monitor).
It's not really worth the time to code it. What I'm really waiting for is something to decode the administrative data side to P25 voice streams. A NAC decoder, yeah, now that's the ticket.
-Wayne
Joseph11
I actually have an original PRO-92, which uses subaudible data for all Motorola Trunking.
A P25 voice decoder for Windows, yeah, that's really the ticket.
