Decoding Mototrbo
Milosz123
Good afternoon guys!
I have a question, how can one decode Mototrbo for not too expensive, I heard that even a Baofeng Radio with OpenGD77 can decode it but im not sure if that is true, could someone please assist me with solutions to decode mototrbo?
thanks alot,
Milosz
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
Welcome to the RR forums. What's your budget? Are you looking for a standalone solution (a la a scanner) or a software-defined radio which requires a computer and software to run? An RTL SDR can be had for about $40 USD paired with a number of apps (DSD+, SDRTrunk to name a few). See other solutions in wiki linked below
1.4 Monitoring DMR
rgchristy
Delco, PA
The Baofeng DM-5R does not. The RD-5R, DM-1801 and DM-1701 will. I have a Radioddity GD-77 and a TYT MD-UV380, which also work.
You have to be careful when purchasing a radio, because of hardware chip changes in recent years. Some work and some don't.
They will not trunk track DMR, either.
Definitely look to opengd77.com for guidance.
The RTL-SDR is definitely an economical option, but will require a computer/laptop/Raspberry Pi to work and won't be portable.
Milosz123
Hello rgchristy, Im looking to purchase a DM-1701. So it can decode Mototrbo? And do you need to download anything extra or will it just do it on the Open GD77?
seagravebuff60
Short Bus Reject
Snow Bird
Yes, a Baofeng DM-1701 will work and fits within your budget. Unfortunately, I used to use them at my previous place of employment.
DSD+ with an RTL-SDR dongle will work as well. Although you mentioned you are looking for a portable solution, you can always run it on a laptop or something for portable use.
Milosz123
Oh alright, how do I make it work on DM-1701? Does it require any upgrades or just Opengd77?
rgchristy
Delco, PA
Thanks sb60! I don't own one, so I don't know either.
I would join the opengd77 forum and read through that topic, asking questions, as necessary.
Roger & Daniel (and others) are the experts! Follow their lead.
seagravebuff60: I remember my first calls in open cab Seagraves, when we had to turn our helmets around backwards during rainstorms...
