There is very little baudot RTTY anymore (apart from a few hams that still use it), but CW is still very prevalent. However not everyone uses the International alphabet.
However there are quite a number of things you can decode (apart from hams). Take a look at this article;
wiki.radioreference.com
As for software, there's quite a list - many can be used by the RTL but you will need a virtual audio cable to make the audio connection between SDR# and whatever software you choose...
and for Virtual Audio cables, see that section here...
Now where to find recent logs? Easy - check the Utility DXers Forum (UDXF) reflector on groups.io...joining up is easy...
The Utility DXers Forum - UDXF is centered around the exchange of news and information relating to "utility" radio stations and signals, below 30 MHz. The Utility DXers Forum - UDXF is centered around the exchange of news and information relating to "utility" radio stations and signals, below...
groups.io
and finally...
The BIG List of RTL-SDR Supported Software
That oughta keep you busy for awhile....Mike
