BCD536HP: decoding
ne5l39437
Ellisville Ms.
Can any one help me with, my uniden bcd536hp? I can not decode my county public survice I can hear them but the signal is very gargaly Every thing else is mine just for the local public survice. I am wanting to listen to jones co Mississippi. Can you help??
ofd8001
Louisville, KY
Supplement to the above:
When you click on the link, you'll see the MS system page. Find the areas that you are interested in monitoring from the lower part - where it says "Talkgroups", Then look under the Mode column. If there is an "E" that means the talkgroup is encrypted, which cannot be received by any kind of scanner.
bee
Belmont, Ms.
The MSWIN system in Mississippi, has a very high "BASS" sound, on the 536.
Some times ir is very difficult to understand. I don't know of any thing that would help.
Maybe someone else can help us.with this!
kb8rvp
Michigan
BCD536HP decoding
I use amplified computer speakers that have the volume control as well as base and treble so you can control the base. You can also play around with narrow and wide FM to see if it changes anything.
Mike
bee
Belmont, Ms.
Thanks, I have an amplified speaker that has "base and treble". i"ll try that
But i dont know anyrhing about norrow and wide FM.
Thanks agin.
