No. No work
Continous with Error CODE 5-03 and: (Please see user Guide for more information)
But, in the user guide not appears nothing about
Thank and sorry my English.
From the PSR800 manual re that error .. I am sure that the 1095 is exactly the same.
05-03 is a config.bin error ... and it states "Reformat the microSD card using the PC Application. Prepare SD card for use option. Replace the microSD card if the problem persists"
Personally .. I have had no problems with the 1095 even after a power failure last night. I just reprogrammed the card .. and it worked fine.
These are not complex scanners .. and almost all issues can be tracked back to the SD card, or user error.
Unless your card failed, which I highly doubt, a reformat and reprogramming will fix it.
