mmtstc
Ø
On my states Phase I system (MN's ARMER), like many other phase I systems, has talkgroups that either do not allow ENC, have selectable ENC or else have ENC enabled by default.
On the talkgroups are defaulted to be encrypted, i have seen a couple fire departments with a talkgroup that is set to that which is used by our states Bureau of Criminal Apprehension. My question being, since this department is using XTS 2500 portables and don't have the ability to toggle their encryption on or off for ANY talkgroup, is the radio doing the encryption or is the radio system doing the encryption?
I know 2500's can do ADP, but most everything on our radio system is DES if I recall correctly.
The point of this question is, if the system is doing the encryption, then in theory, could you perhaps intercept these transmissions when they are coming from the sending radio since they wouldn't be ENC at that point as they have not yet hit the radio system? Additionally, if I was using my XTS5000 on the same talkgroup, but I had my ENC toggle set on, would my outbound transmission be ENC or would if my in the clear and just allowing the system to take care of business?
I understand that there is no reasonable way of decrypting communications, nor do I have any interest in it, this is more of a general thought i had running through my head.
