Defualt Range Settings
milligandw
Maryland
All,
Does any know what the default upper and lower range settings for Range 1: Special Emerg on the Uniden BC796D are?
I inadvertently changed them and would like to change them back to the factory settings.
Thanks!
David
JoeyC
Senior Member
San Diego, CA
I don't know what you are asking here. There are predetermined search ranges within the 796 that cannot be changed by the user, then there are 10 "range" searches that are user defined.
milligandw
Maryland
Sorry that I wasn't clear enough but I was referring to the 10 user defined range settings.
As it turns out, I found the answer in the default "Search" settings in my BuTel ARC250PRO desktop software. There are pre-defined settings in the BuTel software and apparently I uploaded them to my scanner sometime ago forgot that I had uploaded them.
Thanks for replying just the same.
David
