"While we are not ready to transition to a digital radio network at this time, this equipment prepares the 911 center as well as the agencies we serve to transition to a fully digital radio system in the future."
None for this year. All licenses are analog narrowband. Maybe in a couple of years they will go digital, but currently there is no switch happening. They are getting new radios that are digital capable and new paging system, as well as new system monitoring gear.
Here is the meaning for the Emissions Designations.
4K00F1D 6.25 kHz data NXDN (IDAS, NEXEDGE)
4K00F1E 6.25 kHz voice NXDN (IDAS, NEXEDGE)
4K00F1W 6.25 kHz voice and data NXDN (IDAS, NEXEDGE)
4K00F2D 6.25 kHz analog CW ID NXDN (IDAS, NEXEDGE)
7K60FXD 2-slot DMR (Motorola MOTOTRBO) TDMA data
7K60FXE 2-slot DMR (Motorola MOTOTRBO) TDMA voice
8K10F1D P25 Phase I C4FM data
8K10F1E P25 Phase I C4FM voice (P25 mode in RadioReference.com Database)
8K10F1W P25 Phase II subscriber units (Harmonized Continuous Phase Modulation – H-CPM)
8K30F1D 12.5 kHz data NXDN (Wide IDAS, NEXEDGE)
8K30F1E 12.5 kHz voice NXDN (Wide IDAS, NEXEDGE)
8K30F1W P25 Phase I C4FM hybridized voice and data applications (most commonly seen on trunked licenses)
8K30F7W 12.5 kHz voice and data NXDN (Wide IDAS, NEXEDGE)
8K50F9W Harris OpenSky (2 slot narrowband)
8K70D1W P25 Linear Simulcast Modulation ASTRO (9.6 kbps in 12.5 kHz channelspace)
9K70F1D P25 Linear Simulcast Modulation “WCQPSK” data (per Harris MASTR-V literature)
9K70F1E P25 Linear Simulcast Modulation “WCQPSK” voice (per Harris MASTR-V literature)
9K80D7W P25 Phase II fixed-end 2-slot TDMA (Harmonized Differential Quadrature Phase Shift Keyed modulation – H-DQPSK), per Motorola literature
9K80F1D P25 Phase II fixed-end 2-slot TDMA H-DQPSK data, per Harris MASTR-V literature
9K80F1E P25 Phase II fixed-end 2-slot TDMA H-DQPSK voice (interpolation of MASTR-V literature)
11K2F2D Audio frequency shift keying within a 12.5 kHz channelspace (commonly used for 1.2 kbps packet, FFSK station alerting, and AFSK outdoor warning siren signaling)
11K2F3D DTMF or other audible, non-frequency shift signaling, such as Whelen outdoor warning sirens or “Knox-Box®” activation
11K2F3E 2.5 kHz deviation FM "narrowband 12.5 kHz" analog voice (FMN mode in RadioReference.com Database - may also be 11K0 and 11K3 bandwidth) This is what the County Licenses all show.
