Dekalb County
maddogdecker
Dekalb County, IN
I'm unsure how many people know. But Dekalb County is going to Central Dispatch. They are in the process of building the Central Dispatch now. The lastest I heard was possible move is in June or July. That means Garrett & Auburn will be under County Dispatch. I know that Garrett Dispatchers are losing there jobs when the move happens.
Auburn PD has moved all Police communications to the Safe-T Network now. Unsure what's going to happen to the EDACS system they where using. So far I haven't heard anything on the EDACS since the move.
Garrett PD still using there frequency, They do have Safe-T on there radio's but rarely use it.
County still dispatches on VHF for Fire & EMS.
shauno
Porter & Lake County Indiana
That really sucks that the Garrett Dispatchers are loosing their jobs. Lake County is in the process of putting their Central Dispatch together. I hate to see how many dispatchers out of the 18 psaps are going to loose their jobs.
trido
Retired 32 years scanner sales
Southern In
Do You know if radio ref database has all AUburn PD Safet talk groups?
If I haev this right on edacs they seem to have atleat 5 talk groups?
However on Safet I only see ONE?
I havea customer wanting a Home patrol I am thinking wrong scanner for there right now.
reason unless he spends another 100 dollars for EXT upgrade so it can be in id search mode.
He be better off 996
maddogdecker
Dekalb County, IN
Auburn has not used any other tags on safe-t since going to safe-t. I'm aware of the other tags on the edcas. I have an eye on what is going on. Once everything goes to central dispatch is when everything well take shape.
angola_fire
Northeast Indiana
They are on a new 800 digital system. They were using the SAFE-T system which is also digital. I'm attempting to locate the new control channel, but I may be too far away. Time to look up the FCC licenses.
deeplist
Auburn, Indiana
I am pretty certain this started today. Last night there were still dispatchers in Auburn and DeKalb's PSAPs separately. But today the county and Auburn PD were both calling "central" instead of their old dispatch. There was also a large amount of traffic on 15520, which was formally labeled as "County Ops 4" but is now listed as "unknown" in the database.
deeplist
Auburn, Indiana
Auburn's EDACS system is now completely off the air. I haven't heard anything about what the plans are for it, if any. Attempts to get info from Chief McCoy have proved to be futile as he just replies with vague answers like, "we're looking into possibilities."
scannerfreak
Well Known Member
Indiana
That's because some of the talkgroups are now assigned different than what we first had them listed as when we entered them into the DB years ago. So we'll need confirmation on what those are being used for :)
deeplist
Auburn, Indiana
From what I have heard over the course of the day today pretty much confirms that 15520 is now strictly used as County Sheriff Dispatch and 15504 now appears to be a central inter-op channel.
I still don't know about these four (15568, 15584, 15600, 15648), but I would imagine that Auburn Fire will probably get assigned one of them before too long. As far as I know they're still using their local VHF repeater. I wouldn't be surprised if Garrett fire gets one also in time. I'll keep listening.
scannerfreak
Well Known Member
Indiana
Guys, plug these in and be on the lookout. These are also DeKalb talkgroups but we do not know the assignments on them.
47920
47936
47952
47968
maddogdecker
Dekalb County, IN
Scannerfreak,
Where did the those tags come from? I will put them into the scanner tomorrow when I get home from work.
Steve
maddogdecker
Dekalb County, IN
deeplist,
Do you listen to Noble County? I'm unable to pick up any Law Enforcement on Safe-T. I currently use a pro 106. I have all the control channels in the scanner but I don't pick up anything. I do however pick up Fire & EMS from Noble County. If you could let me know that would be great.\
Steve
scannerfreak
Well Known Member
Indiana
Scannerfreak,
Steve
A little birdie told me :)
Thanks and let us know if you hear anything on them. They may or may not be in use.
Daniel
NE Indiana
It appears that TG 15600 is Auburn Fire Dispatch found from the Med run that they had this afternoon just prior to 3 PM.
